Coolant in carb line
Lucanus
Post by Lucanus »
I am by no means a mechanic but I took the carbs off the superhawk and there was coolant in one of the lines....this can't be right!
Just to let you know, I am not the owner of this bike (gixxer owner). Friend of mine had this bike for about 6 years and sittin for 3 years, I told him I could probably get it running.
I am assuming the bike was tipped over or sumthing. Could it be a seal etc?
Any opinions will be appreciated. Love to get this thing running, never rode a twin and I am considering buying it. thanx
Lucanus
Post by Lucanus »
never mind...read up and found out hot coolant runs past the carbs to prevent icing....
sorry....should of researched before hand
Lucanus wrote:never mind...read up and found out hot coolant runs past the carbs to prevent icing....
Welcome aboard Lucanus :!: :) glad you've sorted out your question :!:
Lucanus
Post by Lucanus »
thanks....I have a new problem now. Carbs all cleaned up (alot of junk in them) new pilots as the other ones I could not unclogg fully, everything buttoned back up......check the tank and its full of rust!
Gonna have to buy a fuel tank repair kit....hopefully it works.
Stormin Ben
Post by Stormin Ben »
You can get some stuff that you pour into the tank and then swill around to bind all the rust together and coat it to stop it flaking
I reckon you'd need to remove the fuel tap and blank off the hole when you do it though coz if you don't you'll shag the fuel tap!!
Also be worth getting an in-line fuel filter for when you re-assemble it to stop any later debris from finding its way into the carbs/ engine
But its not a very good one!
Lucanus
Post by Lucanus »
good idea about the in-line fuel filter...will do that for sure thanx
Stormin Ben
Read this website
http://www.motorcycleanchor.com/motorcy ... krust.html
It goes into quite a bit of detail regarding the options (a,b,c, or d) and gives the names of the products I was thinking of
Lucanus
Post by Lucanus »
sounds pretty simple enough to do...I checked with my dealer and they have a 3-stage kit in stock. Going this afternoon to get it. thanx again and will post again regarding the out come..
