The Front Sprocket (clutch cover) - Can you just take it off
Tempest
Post by Tempest »
The black metal cover which you have to remove to gain access to the front small sprocket (also has clutch thingy going into it)
Can you just unbolt it and pull it off?
Anything fall apart or come out when you do this?
What about the clutch mechanism?
No, You are fine, just pull it off
but dont squeeze the clutch lever or it will be a bugger to get back on.
Tempest
Post by Tempest »
Pete.L wrote:No, You are fine, just pull it off
Cheers for that.
Just wondered (never having done it before)
