OK. So how many modifications have YOU made?
- LotusSevenMan
Just considering what mods we all make to our VTR's and started thinking what I'd done in two months of ownership. It already had a chain oiler, double bubble screen, 6mm raise plate under rear top damper fixing, fender extender, removeable clock on velcro, Scorpion cans, hugger and a one less tooth front sprocket when I got it.
In no particular order:-
Handlebar raisers (19mm).
R/R to Yamaha R6 one (as per the sticky).
Remote activated talking (!) alarm system and immobilisor.
Heated handlebar grips.
Digital gear indicator.
Ultrabright 6 x LED's position light 'bulb'.
Tinted headlight cover.
50% more light headlight bulb.
Wider (100mm) extensions on mirrors.
How about the rest of you?
PS Edits due to remembering more bits as I think about it!!!
Last edited by LotusSevenMan on Thu Nov 23, 2006 11:46 pm, edited 4 times in total.
I did the following to one of my VTR's a few years ago,
Spondon ears on the frame, Spondon triple box swingarm, quick release wheel mechanism front and back, dymag wheels, harris rear caliper and non oe disc, 520 chain and sprockets, penske rear shock, alloy subframe, oneoff rear sets, 916/MV carbon seatunit and MV back light, oneoff billet yokes, 97 blade revalved forks, carbon T595 mudguard, renthals, SPA oneoff dash, home made complete loom with programmable race ignition, fuel pump, modified carbs with carbon mounting brackets, modified airbox, close ratio gearbox, moriwaki HC pistons, ported and gasflowed heads, stage 1 moriwaki cams, modified and vented engine cases, japenese market lighter clutch springs, vertical mounted oil cooler with QD couplings, acerbis headlamp with projector lamp, AP GP brake discs, PFM 6-pot calipers, full titanium moriwaki system, braided lines all round, think there is more but my memory fails me.
what mods
Spondon clipons
Fireblade 929 front wheel polished & powder coat
Fireblade 929 forks
Fireblade 929 front fender
Fireblade 929 front rotors
Fireblade 929 yokes
Fireblade 929 front calipers
Hel braided lines front and rear
Clear headlight protector
Renthal Grips
Probolt brake res covers/engine bolt kits/yoke nut ect
K & N filter
Billet bar ends carbon/gold
Flush mount mini cateye indicators (front)
R&G fork protectors
White power steering damper
Gilles rear sets/carbon heel protectors
VFR single sided swingarm (polished & powder coat hub)
VFR rear wheel polished & powder coat
VFR rear caliper powder coat
VFR rear disc
Ohlins shock
Custom made billet suspension linkage/engine tie
Pyramid undertray
Renthal sprockets
Tsubaki xring gold chain
Blueflame oval evos twin port end cans
Custom made header pipes and link pipes to be made this week
Small numberplate
Mini flush mounts leds indicators (rear) mounted to brake light
i think thats it but loads more to do!!!!!!!
Alan
Delmeek did you do the 916/mv unit yourself?
i have been thinking of changing the rear unit for a while i like the mv one also the the new r1.
Fireblade 929 forks
Fireblade 929 yokes
Renthal Grips
K & N filter
R&G fork protectors
VFR rear disc
Ohlins shock
Pyramid undertray
Renthal sprockets
Small numberplate
Alan
- LotusSevenMan
sp1 master cylinder.....ebc contour discs....gixxer 750 calipers...rogered forks...penske rear shock...K&N filter and dynojeted...vrf 750 throttle ..
braided cables front and rear...Moriwaki bellypan [the coolest]..43 tooth rear and 15tooth front sprockets..DiD Xring chain..kevlar clutch plates and racing springs...carbon can co zorsts...flush indicators [front] screen..headlamp cover...tapered footpegs...zorst hangers..top yoke cover...hugger...
I AM THE STRANGE MAN YOUR MOTHER WARNED YOU ABOUT......
Have a sweetie and stop crying........
[Werthers Original...they never get rid of the taste]
mods
LotusSevenMan wrote:Geez Alan.
More Honda bits from other bikes than the original VTR bits left!!!!
I think once you start to modify it goes on and on well it does in my case
alan
Toasted sandwich maker
Kettle
Foot spa
Coffee Maker
Duvet
Cuddly toy
Oh, sorry, got confused
OK
Heated Grips
Resprung forks
Hagon rear shock
Yokes dropped 8mm
Bellypan
Hugger
Scottoiler
Larger rear sprocket
mini indicators
Scorpion cans
Cruise control (throttle lock - now moved to TDM)
Digigear indicator
Seat recovered and reshaped and piped
Gold fasteners and mesh on rads
Double Bubble
Twin rocket launchers for dozy Dorises in their Volvos ( I wish)
Kettle
Foot spa
Coffee Maker
Duvet
Cuddly toy
OK
Heated Grips
Resprung forks
Hagon rear shock
Yokes dropped 8mm
Bellypan
Hugger
Scottoiler
mini indicators
Scorpion cans
Digigear indicator
Double Bubble
Hi all,haven't really finished my bike yet but here's a list so far from from front to back : fireblade 929 front end conversion
converti bar clip-ons
fill and re-drill for sterring lock,spacer for ignition barrel
hel brake lines
wave discs
RC45 throttle tube
sigma bike computer
black double bubble
thurn motorsport front fairing(makes it look like an endurance sp1 with projector head lights
hyper pro steering damper
dyno jet,k&n filter,ignition advancer
powder coated frame and swing arm,sub frame
harris rear sets
geared down to 15t at front
rear hugger
rear wave disc
WP rear shock
mario nava seat unit
free street designs undertail
fuel carbon oval cans
r1 regulator/rectifier
rear brake switch in the brake cylinder
all the usual pro bolt stuff
all i have to do now is put the bloody thing together and get it all working together!!!!!!!!!
hel brake lines
wave discs
RC45 throttle tube
sigma bike computer
black double bubble
harris rear sets
rear hugger
rear wave disc
WP rear shock
If it ain't broke,fiddle with it!
- LotusSevenMan
mods
Hi Del
are they the mv ones on ebay fiberglass copys? Or would a original 916/748/998 do.
What did you do about the subframe?
Alan
Alan
Paul (Stratman) I think, after reading your first list you need to get out more
Excellent mate
Double bubble screen solid black (Skidmarx)
Fender extender
LED mini arrow indicators & different flasher unit
Scorpion hi-level oval race cans s/steel
Maxton spring on rear shock
Volt meter
Mirror extenders
CCT's modified
Split-fire spark plugs
Rear mudguard shortened
Later type clip-ons
Mini clock
Polished exhaust headers
Art crash bungs
Fender extender
Volt meter
Mirror extenders
CCT's modified
Later type clip-ons
Mini clock
Art crash bungs
- SILVER ZIPPER
Greetings from across the Pond (Canada). My VTR is now in hibernation but here is the list of mods I have performed so far:
Micron high-mounts
heat-wrapped exhaust headers
Dynojet kit (dyno tuned)
modded airbox (`Bernie Morgan" mod, removal of ridge in lid and lip on stock air filter)
lenghtened intake runners
15/43 gears & 520 chain & aluminum rear sprocket
Sargent seat
Heli-Bars
high windshield (painted black from the inside)
GenMar mirror extenders
RC51/SP1 front brake MC
Galfer braided-steel brake lines
EBC HH brake pads
Puig hugger
Race Tech modified stock shock
5mm spacer on rear shock
Race Tech 0.80 kg/mm springs
modoified fork cartridge (as per Roger Ditchfield)
forks raised 8mm
SRS fork brace
Shindy steering damper
Mototeck undertail with rear signal lights
LP tank bra
lightened flywheel (work by Roger D.)
Flo-Commander
Sharkskinz (matched paint) lower
heavy bar ends
RC45 throttle tube
ZX9 passenger pegs with 13 mm deep socket spacers
low friction wheel bearings
painted red "parking" light
55/100 W headlight
wheel stripe kit
The result: one fine VTR
Micron high-mounts
Sargent seat
Heli-Bars
EBC HH brake pads
Puig hugger
forks raised 8mm
SRS fork brace
LP tank bra
Flo-Commander
heavy bar ends
RC45 throttle tube
55/100 W headlight
wheel stripe kit
