What is the best in your opinion I am using castrol but find chain dries quickly and clicks.
CaperJ
Chain Lube
I use castrol chain wax on mine, but I cleaned the chain thoroughly before applying it for the first time. I clean the chain properly once a fortnight and re apply, I also give it a quick squirt in between after going out for a run when the chain is hot. Since using this method I have had no trouble and have not had to adjust the chain since, but I am considering getting a scottoiler.
I have always used castrol chainwax,but I was talked into useing repsol fully synthetic lube(very expensive!!!
)and was told you get no fling,but I got fling on the first application
then none after.On having the lube tested(I work in the aircraft industry)it seems very strong and my chain looks to be in good nic
noise polution?,you should see my MPG!!!
VTR1000fw,scorpian cans,dynojet and K&N all wrapped up in HRC colours.I need a HRC avatar!.
Chain WAX ?
I have what is called chain lube it is black is that the same ?
