I have a stage 3 tuned Moriwaki VTR and it is a bit sick!
I suddenly lost power at Snetterton race track and it developed a clatter coming from the front cylinder. The bike ticks over ok but the clatter starts as the revs rise. I have had the head off and it seems ok. Any ideas?
If all seems well up top then I would say it sounds like ether you ends are shot or you have piston slap(but this normally causes oil burn ie blue smoke out of the cans)due to the rings being shot.
Hope its none of the above and its just somthing come loose,best of luck!.
noise polution?,you should see my MPG!!!
VTR1000fw,scorpian cans,dynojet and K&N all wrapped up in HRC colours.I need a HRC avatar!.
That all depends on the wear and tear thats already there,best way to check is to turn the engine over(BY HAND)and inspect the bore for scrapes and marks,also I drop the oil and strain it to look for metal bits as this is a good sign that the ends have gone(bronze or white metal flakes).
Good hunting stormy
