R1 mirrors
dookie
R1 mirrors
Post by dookie »
Heres the r1 mirrors i fitted about a month ago
ri mirrors and stems fitted to storm fairing brackets and with a bit of the r1 gaitor inside the storm one.
stick out farther and the mirrors are bigger so much better all round
and they dont look too bad do they ?? opinions wanted
There was a time i used to care
yellowtrev
Post by yellowtrev »
Look good Dookie.
Iwas thinking about changing mine because the view is so poor.
Does it matter what year R1?
dookie
Post by dookie »
yellowtrev wrote:Look good Dookie.
i got them off fleabay m8 they were listed as long stem r1/r6 mirrors
only paid £10.50 for them and i havnt damaged any storm bits so i can change my mind and go back.
You can fit them as they come but the rubber gaitor looks a bit out of place and there spring loaded into a position that puts the mirrors too far in , so i cut the pin on the joint and simply bolted it into storm bracket , you have to mess with bits of gaitor as the r1 stem is thinner than the storm one .
Squiffythewombat
Post by Squiffythewombat »
OMG! how on earth do you filter with them tho?
Squiffy_The_Wombat
