Calling All 15T-43T Sprocketees
Hey guys,
I've just finished putting on a new chain. Decided to go with the 15 Front, 43 Rear tooth combo. Standard x-ring chain. Seems to be a popular choice on this forum.
Now I am just wondering could I have got away with removing another link from the chain. If I look at the rear axle adjuster, there a gap of about 1.5cm to the front of the axle. I am wondering if I removed a link, would I run out of space by pushing the axle forward? If what I am saying makes no sense at all, I will post a few pics. Its fine at the moment, but as the chain stretches I might hit the most rear setting that the axle will go when adjusting it in future.
Cheers!
Cheers!
- marlbororman
- Squiffythewombat
- Contact:
Wow!! Just took the bike out for its first spin with the new ratio. Acceleration is fantastic... love that new smooth feeling with a new chain. The first handful of throttle I gave it had me fishtail on a slippy road!! Did get get any front wheel lift, but roads not really the best at the mo - muck everywhere!!
A highly recommended mod!!
Squiffy - I will do just that - if I get to the max adjustment, I will take a link out and move it back...
- LotusSevenMan
Cheers guys
Was bored... !
As for the lights Chris, I was mucking around with these a while back - I added them for extra visibility... Do a lot of filtering so figured I might as well. I have a switch for them but I also hooked it up to the 'passing' switch which meant I could give lane hoggers a good old flash if they were holding me up on the motorway
They also come on when full beams are on so a bit more light than from the standard headlight. (Excuse the state of the bike - its filthy! A rare occurence
Cheers for the pic's Pmcq. The light's are smaller than I had expected and therefore don't look that much out of place IMO
Night time vision must be well improved
I see you've now added another pic to your signature, that one I do remember, well apart from the extra large can's and tail fins that is
- Squiffythewombat
- Contact:
Hey Squiffy - I just picked them up in a motor factors actually. Then I just bought a relay and some wire and some rubber tubing to route the wires past the engine. I must do up a wiring diagram for this! I actually fitted a second relay so that when the passing switch is pressed they come on. That relay is mounted in behind the speedo.
The lights themselves are mounted onto some small brackets I made. These are attached to the rad mounts and as they are hollow and you can put a bolt up through it.
Hey Chris - that last pic on my sig I like to think of as the dune-buggy mod.
- Squiffythewombat
- Contact:
