More Problems with the SP
Seeker 77
Post by Seeker 77 »
There is bluish smoke coming out of the rear cylinder exhaust can, any thoughts? It can't be a generic problem as there is nothing coming out of the other silencer.
Am thinking it could be a gasket on its way? It recently had its clearances done so it shouldn't be the valves.
Any help would be much appreciated....
Hi Mellis,
This doesn't sound good 8O Is it all the time or just when starting from cold? Have you recently had an oil change? Has it only been doing it since the valve clearances have been checked? Are you sure it's oil and not a corrupted power comander map pushing too much fuel through(Smoke more black than blue)?
VTRbob
Post by VTRbob »
blue smoke is usually oil,if its burning oil its getting past the piston rings OR its getting past the valve stem seals,run your finger round the inside of the end can to see if its sooty or oily,it don't sound good :(
Seeker 77
Post by Seeker 77 »
It only does it when hot, and only when you blip the throttle. It doesn't affect the performance at all but the smoke is definitely blue :cry: :cry:
I fear a quick sale may be on the cards......
The other thing that i was thinking was that it may have been caused by a little V-max trip up the autobahn, speedo reading 184 :oops: Maybe that has caused the problem.....
Mellis Said
The other thing that i was thinking was that it may have been caused by a little V-max trip up the autobahn, speedo reading 184 Maybe that has caused the problem.....
Jammy git, Iv'e got to make do with the M4 and I can't get mine over 70 nomatter how hard I try :wink: .
Sounds silly but keep and eye on your oil level. If the preformance is still there (and it obviously is) it could just be a leaky valve seal. That wont cause much of a problem unless you start burning a lot of oil.You coud pull your plugs out and see which pot is causing the trouble by the colour of the burn. If it's loosing/using a lot of oil I'd get it into a work shop and hve an estimate before you descide to flog it. It could even be a leaky gasket and not cost too much at all.
Seeker 77
Post by Seeker 77 »
Will try that mate, thanks :wink:
I would agree with whats been said :!:
Blue smoke = it's burning oil :!:
Possibilities as already mentioned, if it's only valve stem seals it usually smokes more on start up than when riding it, if it's a piston ring gone that's usually more noticable after going down a steep hill (using the engine for braking) once you open the throttle to power up the other side, the best way to check the latter is for a mate to follow you :!:
Just a thought (probably a load off boll**ks) I don't suppose you've been wheeling your bike a lot just lately, like since this problem has occured :?:
Cheers,
Seeker 77
Post by Seeker 77 »
How difficult/hard to change is a piston ring??? Or more likely, how expensive will it be to get someone to do it for me? 8O 8O
sirch345 wrote: Just a thought (probably a load off boll**ks) I don't suppose you've been wheeling your bike a lot just lately, like since this problem has occured :?:
Cheers,
Well have you :?: :?:
Seeker 77
Post by Seeker 77 »
No, not really!! Does that make it more or less likely to be the piston ring!!?
mellis wrote:No, not really!! Does that make it more or less likely to be the piston ring!!?
It was only a long shot :!:
I know some of the Ducati's if wheelied a lot end up with oil from the engine in their airbox, so working on that, I just thought, may be you had oil in your airbox and it had found it's way into the engine via the air intakes, which would give you the same symptoms :!:
Seeker 77
Post by Seeker 77 »
Thanks Chris, will pass it on to the engineer folks! Mark
mellis wrote:Thanks Chris, will pass it on to the engineer folks! Mark
You're very welcome Mark :!:
It's a abit of a mystery really, as I would have said Honda engines on the whole are normally pretty bullet proof in that department :!: Hopefully it won't be to serious :!:
Nows there's a good thought Chris. Mellis, take the tank off and have a look inside the air box. If you've been over reving on the auto bon it's quite possible the breather pipe from the cam cover has spat some oil into the airbox. I used to have that happen every now and again on the Storm it might be the same on the SP.
I still think it's unlikely it's an oil ring.You'd loose performance and leave a smoke trail like a two stroke 8O
KarlosVTR
Post by KarlosVTR »
Rings mate
without a doubt
