Red
Posts: 57 Joined: Thu Jan 04, 2007 1:50 pm
Post
by Red » Wed Feb 28, 2007 9:56 pm
Please don't laugh, as I ask yet another silly newbie question.
But I am getting a new chain and sprocket set fitted at the weekend and wondered whether I have to run them in?
Should I take it a bit easy, as I normally do like to push it over the ton. (On private roads of course mr policeman, honest)
I'm an insomniac agnostic dyslexic. I lay awake at night and wonder if there really is a dog.
curly
Posts: 522 Joined: Thu May 01, 2003 7:08 pm
Post
by curly » Wed Feb 28, 2007 10:45 pm
Good question!
I had a new chain and sprockets fitted last October but I just thrashed it straight away and everything seems OK.
So hopefully the answer is no, you don't have to take it easy!
Kitch
Posts: 1548 Joined: Fri Apr 28, 2006 7:05 pm
Post
by Kitch » Wed Feb 28, 2007 10:52 pm
Expect the chain to wear faster as it beds in.
This means you should check the tension and adjust it as frequently as needed for the first few hundred miles.
Also, give it a good lubing as the fitter might not have and it will vary from being factory lubed to dry.
Posts: 22397 Joined: Mon Aug 25, 2003 10:35 pm
Post
by sirch345 » Wed Feb 28, 2007 11:38 pm
Kitch is spot on
Red
Post
by Red » Thu Mar 01, 2007 12:16 am
Thanks for the advice guys
Kitch
Post
by Kitch » Thu Mar 01, 2007 12:41 am
sirch345 wrote: Kitch is spot on
you said that like you were suprised....
LotusSevenMan
Posts: 1915 Joined: Wed Sep 06, 2006 8:32 pm
Post
by LotusSevenMan » Thu Mar 01, 2007 9:01 am
Especially one trying to commit sexual suicide in the local park!
KarlosVTR
Posts: 473 Joined: Sat Dec 30, 2006 6:21 pm
Post
by KarlosVTR » Thu Mar 01, 2007 11:03 am
tip - do not lube it with the new formula castrol chain 'wax'
its utter shite compared to the previous lot
it works better as a cleaner ffs and thats why my starter motor is clean and my chain rusty
Monkey!
Posts: 29 Joined: Thu Apr 06, 2006 10:00 pm
Post
by Monkey! » Thu Mar 01, 2007 5:40 pm
I agree with Karlos.
The old Castrol chain wax was good stuff. White waxy stuff that seemed to do the trick.
But the new stuff is clear, colourless and about as much use as underpants on a haddock.
Monkey!
I may be mad but at least I'm not dead. Yet. And long may that be so.
Stratman
Posts: 2656 Joined: Mon Dec 01, 2003 10:55 pm
Post
by Stratman » Thu Mar 01, 2007 6:00 pm
Get a Scotoiler.
Chain will last for over 30,000 miles with one. In fact, my chain was 35,000 miles and it was still OK, but as I was changing the rear sprocket for a larger one anyway I had the lot changed at the same time.
Kitch
Post
by Kitch » Thu Mar 01, 2007 8:10 pm
you would if he was telling you when to cross the road, or the way down a mountain, or when the postman is coming, or what to do with new bike chains.
Post
by sirch345 » Thu Mar 01, 2007 11:00 pm
Kitch wrote: sirch345 wrote: Kitch is spot on
No, definitely not surprised
Jaglifter
Posts: 799 Joined: Mon May 03, 2004 7:35 pm
Post
by Jaglifter » Fri Mar 02, 2007 11:40 am
Having spent year with Go-karts I've used lots of diferent chain waxes. I generally find that if it says "wax" its shite. The grease type stuff seems to work better - I used silkolene mostly.
Anyway, I find that painting the chain with EP80/90 gear oil works fine for the SP - don't forget they're supposed to be lubed for life anyway.
Gone are the days of boiling in graphite grease.........
She's my idea of beauty and thats what I ride.
BIG STEVE
Posts: 62 Joined: Tue Jan 30, 2007 9:41 am
Post
by BIG STEVE » Fri Mar 02, 2007 12:26 pm
I use the silkolene (throw back from the enduro days)
what i find to be the biggest pile of BS is the statement "anti fling" FFS
the stuff goes everywhere
Lying gits
sh1t HAPPENS !!!
