Caliper bolts.
yellowtrev
Caliper bolts.
Post by yellowtrev »
Hi everyone,
Took my front wheel out to have a fresh tyre put on and in the manual it advises to replace the caliper bolts.
May seem a silly question but are they 'special' material bolts,hardened steel or similar? :oops:
Or can i just go to an engineering supply shop and get 4 bolts,same size,thread etc? :?
Many thanks.
Stratman
Post by Stratman »
No need to replace the bolts. and yes, they are special HT ones.
The Honda ones are pre treated with a Loctite compound. You can clean up the old ones with a wire brush, degrease them with meths and use Loctite to "lock" them no problem. I have done this with mine many times without any problems. Just make sure you torque them up correctly.
VeetyR
Post by VeetyR »
bit o loctite on the end and a smidge o copperslip up the thread as this will stop corrosion that will make them difficult to remove next time...VeetyR
Keep it gutter...Keep it grimey..........one!
Stormin Ben
Post by Stormin Ben »
Coppaslip?
Loctite?
Nah, I've not used either
Just torque 'em up to the right settings and away you go (NB I dont clean them up either :) )
But its not a very good one!
