carb breather fix....question......
VeetyR
Post by VeetyR »
Hi guys,
Want to do this mod as i think it may not have been done.........so a quick q for ya.....
This breather pipe i am looking for.......Sitting on the bike is it on the left or right hand side??
Cheers people :)
Keep it gutter...Keep it grimey..........one!
:D Both :D
Not very helpful was it :lol:
If you look at the carbs from the right hand side as you sit on the bike you can see two breather pipes between the two carbs. These are the ones you are after.
VeetyR
Post by VeetyR »
so its the smaller breather that enters the bracket on the right and the smaller one in the left?
Or both of the right hand ones?
VeetyR wrote:so its the smaller breather that enters the bracket on the right and the smaller one in the left?
Yep! Them's the one's. Chris's pic isn't working at the mo
Doh!
Now It is 8O
KarlosVTR
Post by KarlosVTR »
so what needs doing exactly? ive got a bitch of a problem with it stalling under ferrocious braking and cant make out the pic :oops: . is it basicly turning them from inner facing to outer facing?
and that cures it?
Yes
the pipe is bent through 90 degrees to enter the carb brackets in std trim and can pinch and make a vapour lock. Basically you are just letting them hang so they dont bend and cause a blockage
KarlosVTR
Post by KarlosVTR »
i think this ought to be made a sticky, along with other stuff............
VeetyR
Post by VeetyR »
Ok i have pulled out the 2 smaller breathers 1 from left and 1 from right carb brackets.......These were the 2 smaller ones rubber banded together between the carbs and left them hanging down....i take it this is right??
also....they are quite long......can i trim them without affecting the carburation?? i just dont want em to foul on anything under there.
VeetyR
That's the ones :lol: Job Done! :lol:
I never heard of anyone having a problem trimming them down, I can't see why not.
I do know It doesn't always cure the problem so why don't you wait a bit and see before you chop em up it iddy biddy pieces :wink:
Good luck
LotusSevenMan
Post by LotusSevenMan »
Wish this was 'up' when I had the bike in bits recently!!!!!!!
Only put the tank back on today (and it ran. Hurrah).
Can this 'mod' be done in situ without taking lotsa stuff off (too dark tonight to see this breather etc) ?
LotusSevenMan wrote:Wish this was 'up' when I had the bike in bits recently!!!!!!!
If you don't have the engine stalling LSM after very hard braking then I wouldn't worry about it :!: :)
LotusSevenMan
No, I'm smoother than that.......................... and so's the riding style :roll:
VeetyR
Post by VeetyR »
well i did it without taking anything off.... and i got quite big hands too( and we all know wot that means.........big gloves :lol: )
