chain lube
balls
chain lube
Post by balls »
can anyone recomend a good chainlube that does not fly all over the place 8)
Wildfire
Post by Wildfire »
Personally - I use Castrol Chain wax at the moment...seems pretty good and doesn't fling off too easily. About £5 a can if I remember right
Zakalwe
Post by Zakalwe »
Wurth Dry Chain wax....great stuff £5-ish delivered from e-Gay HERE
recomended! (get the chain/brake cleaner as well...also good tackle)
Wroey
Post by Wroey »
I'll second Zakalwe there, the Wurth dry lube is brilliant stuff .... Was also recommended by my local Honda dealer, they use it in the workshop !
It leaves the chain slightly white, which is always a good thing so you can ensure all the chain gets a good all over coat.
