Help CCT?
Help CCT?
Hi All,
Can anybody who's experienced CCT failure describe what the noise ( prior to failure) the engine started making, and could you hear it when riding it or only when stationary, any help would be appreciated.
cheers Chris.
cheers Chris.
Hi Chris,
Not long having experienced the same thing. Mine went at about 80mph while changing down. I heard nothing before it went, no tapping or knocks etc, but when it went it was like as if the valves had all come down and were slapping the top of the piston. I'm guessing the noise was actually the chain whipping around inside because it had no tension.
Not a bad job to do, I was lucky that all that was wrong was the CCT went, and no other damage was done. Check out the messages below regarding the CCT's there are 3 pages about them on the last subject mailing ! Did it myself in about 1 hour. My mate likened it to scrap - heap - challenge ! If you need more details as how to do it, give me a shout back.
Ronan.
Ronan.
FAO RQ
Hi Ronan, thanks for the info, looking at earlier thread I see you quoted a price of 72.44 including gaskets, for the pair, was vat and p&p on top ? the reason I ask is I rang Will Lewis at Chiswick today and was quoted a lot higher price, Will is getting back to me tomorrow hopefully with a better price but I doubt it will be that low, cheers Chris.
Cam chain tensioners VTR
Hi Ronan, my bike is making a noise which sounds like a patter which you can only hear when changing down using engine for breaking ie when coming up to a junction when you are going fairly slow, when the bike is stationary you can hear a rattle at 2000 to 2500rpm but not everytime, I am going to check it out, thanks once again for your help, Chris.
Drink to contentment not to capacity. I just haven't figured out which comes first.
CCT Advice
Thanks Martin for advice, in the middle of stripping mine down, but to my supprise front tensioner o.k. while i'am at I think it wise to replace both
cheers Chris.
cheers Chris.
Re: Cam chain tensioners VTR
HELLO MY FIRESTORM IS MAKEING THE SAME NOISESsirch345 wrote:Hi Ronan, my bike is making a noise which sounds like a patter which you can only hear when changing down using engine for breaking ie when coming up to a junction when you are going fairly slow, when the bike is stationary you can hear a rattle at 2000 to 2500rpm but not everytime, I am going to check it out, thanks once again for your help, Chris.
HAVE YOU SUSSED OUT IF IT WAS TENSIONERS OR NOT
CAN GET THEM FITTED BY HONDA MECANIC FOR £50 AS A
HOMER.
HAVE FITTED DIABLO TYRES HAS ANY ONE ELSE TRYED THESE!!
- Stormtrooper
HELLOStormtrooper wrote:no i have not tried the diablos yet, but i am running evo corsas & i think they are pretty good, so yours should be better, keep us posted how you get on
SO FAR SO GOOD WITH TYRES A LOT BETTER THAN
AVON AZEROS WHICH I WAS USING MOR CONCERNED ABOUT
RATTLE FROM ENGINE WILL HAVE TO LEARN TO SLOW DOWN A BIT
SPEED CAMERAS NOW ARRIVING IN N.IRELAND S***
ATVB PAUL
