I was wondering if anyone could help me. I'm monuting a vtr engine and i'm having a little problem with one of the spacers. Would somebody be able to tell me what tool i need to adjust the frame so that the spacer will fit? From what i can see it's the frame that needs to be adjusted because i can see some sort of thread. I've attached a picture so you can see the bit i mean. The top of it looks a bit like a castle.... I know i know, it's the only way i can describe it.
If somebody could give me some pointers i can go out and buy the tool.
I got a mate to give me a piece of mild steel tube with the right internal diameter. It was a bit tight so I cut it down both sides with an angle grinder and prised it open a bit. Then it worked, but need to be careful not to scratch the fork leg of course (plenty of lubrication helps)
