Oil pressure sensor wire
beesfan
Post by beesfan »
I've started doing the electrics on one of my storms and have hit a wall. The lad i got the bike off mentioned an oil pressure sensor problem and i think i've just discovered it. There are two wires that go to the sensor pickup but one of them is broken, i've attached an image so you can see it. It's not very clear in that picture but it is the green wire that has broken. Where does this go? Does it attach to the same connector as the black wire?
Thanks
beesfan
Post by beesfan »
Doh just realised that its the neutral sensor wire. Ignore my last post. :D
