The problem i'm stuck with is the correct width spacer wont fit. I've attached a picture of what it looks like at the moment, if i made the adjuster bolt smooth and made sure the spacer i fit is in tightly would this be a problem?
I'm a bit concerned that with it like it is i'm going to have problems with the chain lining up? Any ideas on a possible solution?
