Dials
8ball
Dials
Post by 8ball »
I've started a tread in workshop as I have been looking for some new clocks as my bike is an import and I wanted it in mph.
I managed to find a site that will change min from km/h to mph :D but they also do custom work. :lol:
Just thought you guys and girls might find it interesting
8ball
Edit you might want the link lol
http://www.redial-uk.co.uk/index.html
Life fun when doing a ton
LotusSevenMan
Post by LotusSevenMan »
You could always fit a Speedo Healer. Takes about five minutes to fit and the same to calibrate it. Not only will it give you a KPH to MPH alteration it will correct speedo error too. I have found the device incredibly accurate.
We are talking accuracy that was EXACT to the sat nav all the way up to 100mph (OK 100 indicated, 99.5 actual!!!!!!!!!!!!)
http://www.speedohealer.com/eng/intro.htm
It has a loom that fits the FireStorm with the removal of one electrical plug (one in the opaque rubber boot just behind the tank so easy to get to!!!!
V-Thump
Post by V-Thump »
I've the same issue mate, the clock only shows KPH so a new inset is needed. I fitted a sigma bike computer which gives a steady accurate MPH speed, trouble is the little computer is slow to catch up.
Keep us informed of the costings and outcome
8ball
Post by 8ball »
The dial came the next day fitted quite well just needed to make the stop needle hole a little bigger. Took 10 min to fit and it works a treat, cost me 29.99 all in,
