Bit of a puzzle here.
Bled my rear brake about 6 months ago, and then again last night (after fitting new pads)
Somethings odd though.
I have one of those 1 way rubber/clear plastic bleeding tubes which you pop onto your nipple (ooerrrr missus!) loosen the screw and pump away on the brake lever whilst keep topping up the reservoir.
Yet, for some reason,both times I have done this, I never can get rid of the bubbles coming out into the clear pipe.
I've tried the nipple open quite a bit, and also open just a fraction, and must have topped the reservoir up a good 10 TIMES and pumped it all thru, but all the time, there is a constant stream of tiny bubbles in the brake fluid coming out into my clear bleeding pipe.
there are no leaks anywhere in the system, I can't just can't fathom where these bubbles are coming from?
I did wonder if actually they are NOT in the brake line, just getting into it as the fluid leaves the nipple, perhaps nipple to calipur thread is letting air in at the last second.
I really can't see any other way.
Puzzled?
Bleeding rear brake - bubbles never stop coming?
It sounds like the non-return valve isn't doing it's job to me, or the pipe is not making a tight seal around the bleed nipple
You shouldn't need to undo it any more than a quarter to half a turn.
I would try bleeding it in the old fashioned way, shutting off the bleed valve after each compression of the brake pedal and see if you still have as many air bubbles.
Don't forget the piece of clear plastic pipe you will be using needs to be immersed in some brake fluid at the bottom of the jam-jar, stopping any air travelling back up
HTH,
HTH,
The reason your getting loads of bubbles is you need to:
Take the nipple completelty out and on the thread put some ptf tape then screw back in, attach the oneway bleeder open nipple slightly just so the fluid comes out, pump away on the leaver you should not get any air in the tube now.
I have one of these oneway bleeders,and did the above on all nipples without any probs.
