After numerous problems fitting a set of fairing indicators to the front of my bike, it now fails to start after a run up to normal temperature. By that i mean that when I hit the start button......absolutley nothing. No clicks, nothing.
Checked the connectors on the starter relay which were a little rusty so cleaned them up and thought it ok.
I have discounted the alarm as it appears okay. The relevent thing is that it only happens when the bike has reached temp. it'll start all day long off the key in the garage if its only running in short bursts. Take it for a run and it will not start again until its cooled down.
Is it possible that i blew something else as well as the fuses during the indicator install or is this a red herring do you think?
Everything was fine before i tried fitting them that's for sure.
Any ideas peeps????????
She won't restart
Re: She won't restart
I sounds to me like it's a very good possibility it is your alarm that's causing the problemSimon 2 wrote:
- Squiffythewombat
- Contact:
