sirch345 wrote:You will need to remove the original chain guard, then use the two bolts that hold the original chain guard in place.
Not sure what make mine is (picked it up from fleabay a few years ago). It's Carbon fibre and that's all I know about it as it has no stickers or owt on it
Although it uses a couple of the same bolts that hold the chain guard on, it fits over original chainguard.
I removed chainguard at first but then realised it looked stupid and would fit over it - so it was replaced.
Also as Chris says, uses at least one of the brake tube clamp screws.
Didn't get any fitting instructions - just trial and erorr - I suppose there's a few different designs out there.
HTH
Graeme
