Hi
I am new here and could do with some help or advice
After the front cct let go i have changed both front inlet valves plus gaskets and both ccts but now she has developed a misfire at 7000 rpm
she is also a bit of a pig at idle and seems very lumpy the miss appears more or less instantly and does not smooth out i have drained both carbs and pulled the carb breathers out so they hang in the wind but i am now out of ideas has any body got any ideas that i might try .the compression seems right and the valve timing also seems right
Thanks
misfire
- Pete.L
Hi Andy
I think this is right up your street. Follow the link and see what you think.
http://www.vtr1000.org/phpBB2/viewtopic ... ht=misfire
Hi Andy,
This link could also be of help to you
http://www.vtr1000.org/phpBB2/viewtopic.php?t=8326
