I have recently purchased a 1998 superhawk and have had some low end flutter or hesitation. I had the carberators sincronized and that helped, but after a few hours of riding the hesitation seems to have returned. Could my carbs be out of sync again or could it be something else. The bike also has a tendency sputter or backfire through the carbs at low speeds when i give it a little throttle. these problems only seem to happen when my bike has reached the half way point on the temperature gauge. I was told this is the nature of the v-twin. I don't know since all that i have owned up till know is inline four cylinders. I love the bike, but i would like to get to the bottom of this problem so can move on to more important issues. like finding a suitable under fender exhaust.......
Ron T.
Newton ma.
United States of America
low end flutter at running temperature
sounds like it's running slightly lean on the pilot jets. Just try turning each screw out 1/2 (half) a turn and see how it runs. They could be out of balance again. I used to do mine every 2k miles and when you do them blip the throttle alot with the gauges still attached as the adjustment screw in held by a spring and has the tendency to settle in a different position once revved.
Del.
Del.
