MOT
MOT
MOT Day today - and passed no problem, except for the advisory that the rear brake disc is starting to warp. I knew this, this is the second replacement EBC that M&P have sent me. I have rung them and told them I will be getting a Honda one then they can collect the EBC one and give me a refund, to which they have agreed.
- LotusSevenMan
Stratman wrote:No. Evidently Built from Cheese
E B C
Easily Bent disC ?
On the serious side Paul, I don't suppose you have a sticky piston or two in the rear brake caliper, and thats causing the disc to over heat
- tony.wilde1
sirch345 wrote:Stratman wrote:No. Evidently Built from Cheese
E B C
Easily Bent disC ?![]()
So that will be Edam Brie Cheddar (EBC)
On the serious side Paul, I don't suppose you have a sticky piston or two in the rear brake caliper, and thats causing the disc to over heatYou've probably already checked that, but just incase you haven't it might be worth looking at. I'd also check it right-away after you get back from a decent blat
as well as when the caliper is stone cold
Get the rear up on your paddock stand and see how free the rear wheel turns
that was a bit "cheesy"wasnt it chris?
