Looking for cheapest source of wheel bearings and seals for both a 'storm and blade
Quality pattern parts will be fine
Any suggestions
Where to get wheel bearings and seals
Last time I replaced some (they don't get done all that often) I got a full set of front and rear bearings and seals for £34.49 from David Silver. Genuine Honda ones, including 1st class delivery and VAT.
IIRC I didnt find them any cheaper anywhere and even pattern parts where similar money, and in some cases, more expensive.
When replacing my bearings and seals, I opted to do so with C3 type bearings (looser tolerance, higher speed bearings) with low-friction seals. A chap who grass dragged snowmobiles informed me that making the switch on his race sleds dropped friction losses substantially so I thought if it works on a snowmobile.... Anyhow, that was two summers ago (and over 20,000 kms) and all is well. Just something to think about (and any reputable bearing shop should be able to set you up; total cost for the five bearings was $50 CAN). As for the seals, I used OEM stuff.
cheers
cheers
- Stormin Ben
Link to my recommendation
http://www.vtr1000.org/phpBB2/viewtopic ... ght=wemoto
And a couple of other satisfied cutomers
But its not a very good one!
Cheap wheel bearing
Just done the front ones on my 98 model, they were £15:35from WEMOTO.
Bearings and dust seals.
