Duffy's Streetfighter Project
Re: Duffy's Streetfighter Project
It sure is. And I didn't even mention the lack of space BEHIND the rad - a hot cylinder head and no room for proper airflow. That's why the side mount rad was the only option for me.
- bigtwinthing
get a rad and fan set in the passenger seat bit Duffers. It will fit.
How about two vertical rads in front like the SP?
You get front wheel and mudguard clearance that way.
Wow thread revival. That's coming along nicely duffers. It will be good to see it completed.
Yep, I agree you'll get a rad to fit under the seat no problem, but you'll compromise airflow. To work efficiently the rad needs air directed THROUGH it, not over it. Two issues with under-seat:bigtwinthing wrote:get a rad and fan set in the passenger seat bit Duffers. It will fit.
Firstly, the under-seat rad will inevitably face away from the natural airflow. The only solution here is to fit air ducts to route air up and through the rad core, and that'll almost certainly look fugly.
Secondly, you won't be able to efficiently flow the cooling air away once it's passed through the rad. It'll end up under the seat itself (handy for butt-warming in cold weather though).
- bigtwinthing
scubadog wrote:Yep, I agree you'll get a rad to fit under the seat no problem, but you'll compromise airflow. To work efficiently the rad needs air directed THROUGH it, not over it. Two issues with under-seat:bigtwinthing wrote:get a rad and fan set in the passenger seat bit Duffers. It will fit.
I saw one fitted to a bike in Poole 1 night, he had the Ducati 916 init, but the rad was in there, the vents had pipes attached to the top of the rad and a large fan below it, then all covered by mesh, he wasn't about to ask if they had cooling issues though, How about the huge rad fans on the MV Agusta thingy.
- bigtwinthing
bigtwinthing wrote:scubadog wrote:Yep, I agree you'll get a rad to fit under the seat no problem, but you'll compromise airflow. To work efficiently the rad needs air directed THROUGH it, not over it. Two issues with under-seat:bigtwinthing wrote:get a rad and fan set in the passenger seat bit Duffers. It will fit.
I saw one fitted to a bike in Poole 1 night, he had the Ducati 916 init, but the rad was in there, the vents had pipes attached to the top of the rad and a large fan below it, then all covered by mesh, he wasn't about to ask if they had cooling issues though, How about the huge rad fans on the Benelli thingy.
Hi all I know it’s been a while but life has got in the way a fair bit lately but won’t bore you with all that.
I have made a bit of a start on the neglected fighter project fitting a lightened flywheel and Powdercoaters satin black engine and rocker covers,rear footrest hangers,also sprayed oil cooler with Eastwood’s satin black and left hand radiator.
Still loads to do as I need new clutch and front brake lines made due to raised bars, new digital speedo as standard one doesn’t look that nice unfaired and need to sort out some more wiring.
Fitted a new battery and it turns over but not started yet as I need a right hand radiator as mine has cracked brackets.
I have the tank front Mudguard and belly pan painted and stored ready for final fit.
Got fed up wit not using it so going to use standard rads for now but I don’t like the look of them, so will sort that at a later date.
So here are a few photos of how it looks now.
ooh thats purdy.. the rads being black kinda hide the fact they are side mounted
Thanks fella that was the best compromise for the time being as I want to ride the bloody thing.
That's a nice variation on a theme.
It's good to see a bit of care being taken for a change, and some thought going into the appearance of the bike in the photos.
It's not everyone that would have taken the time or had the idea of using a compost bin in the background.
Well I couldn’t beat Mac’s multiple bin shot so thought a change of tactics was in order
Just a shame that them tyres will be out of date soon
About time you got ta cracking on it
Yeah and they were on my fazer thou before thatlloydie wrote:Just a shame that them tyres will be out of date soon
It's been a long wait Duffy
but I have to say the quality of the work looks like it's been well worth it
