Well ..with 103k on her ..time for ground up
Elchappo76
Re: Well ..with 103k on her ..time for ground up
Post by Elchappo76 »
Elchappo76 wrote:
Elchappo76 wrote:
Elchappo76 wrote: Geez ..would you have an idea on $$
Sent from my SM-G900I using Tapatalk
I think my front cyl head ok and vavles .will strp clean and reasemble .small relapping should be ok and seals.Image
Hi tony . Well after pulling my case off .ive discovered more something jus not look write here ...any ideas pls .
Not mention .im intrigued by the difference between front and rear cyl covers .
Elchappo76
Elchappo76 wrote:
Elchappo76 wrote:
Elchappo76 wrote: I think my front cyl head ok and vavles .will strp clean and reasemble .small relapping should be ok and seals.Image
Ok .sorry am aware that this is normal now....just took my att straightaway. .loll
i can't see anything weird, what have you spotted?>
Elchappo76
AMCQ46 wrote:i can't see anything weird, what have you spotted?>
Hi ..sorry just found that its normal for that outer cogg to look abnormal to me.
Elchappo76
Gear is normal, but it seems likely you've had a valve, valve stem seal or guide failure allowing exhaust gas into the cam cover.
Is that piece of metal you found steel or alloy?
Elchappo76
tony.mon wrote:Gear is normal, but it seems likely you've had a valve, valve stem seal or guide failure allowing exhaust gas into the cam cover.
Well it looks lot lime the stainless steel from exh joint seal.
Elchappo76
Yea and my thoughts as well.
Elchappo76
Well i thought cant be too much to a clutch holding tool...so out with the welder again..Image
Elchappo76
Did job ..but bit bent ...should straighten on assembly.
Elchappo76
Question. ..i have noticed the chain here on oil pick up ..to be unexpectedly loose ..is this normal.
Elchappo76
Unexpectedly loose ..is this normal.Image
Elchappo76
Hi tony .. is it normally the only way to remove flywheel with the special puller i supose i have to order in...
Elchappo76
Also is it really necessary to remove flywheel to split case to remove pistons.
yes it is normal for the old pump chain to be that loose
