Standard size piston rings
BillyBear
Post by BillyBear »
Good evening fellow FireStormers,
I am in the process of a 2003 engine rebuild and I am have no luck in finding a set of standard size piston rings. Even spoke to Honda dealers today and was told you need to buy a set of new pistons and the rings come with them
If anyone could guide in the right direction to source a set your help would be greatly appreciated.
Re: Standard size piston rings
No, you can buy piston rings on their own.
Talk to David Silvers.
Don't know where you are located but I have ordered piston rings with no issue :thumbup:
As Tony says https://www.davidsilverspares.co.uk/ for the UK
Or in the USA https://www.ronayers.com/oemparts/c/hon ... ycle/parts
And as Mike (8541Hawk) says about the availability, both of the above list rings only, although David Silver will have to order them in for you, but at least they are still available,
BillyBear
Post by BillyBear »
Thanks guys for the info, sorted now :D
BillyBear wrote: Sat Aug 07, 2021 10:32 pm Thanks guys for the info, sorted now :D
:thumbup: Well done,
