Idle speed
Dazza2910
Idle speed
Post by Dazza2910 »
Had a look in the workshop manual to see how to adjust idle speed, but pictures but particularly clear.
Can anyone shed light on exactly where the screw(s) are that I need to adjust?
Daz
Dazza2910
Re: Idle speed
Post by Dazza2910 »
Should have added, it's a 1999, so carbs!
Re: Idle speed
'97–'05 all have carbs. Though late XL1000V Varaderos have Fi
And idle adjuster on right side of bike
Dazza2910
Re: Idle speed
Post by Dazza2910 »
Wasn't sure if the later ones were injected.
Thanks for that. I thought that's what it was but the page I was looking at showed pilot screws too. Been a while since I had a carbed bike so wanted to check!
DazImage
Re: Idle speed
If you've not done so already sort the throttle position sensor then balance the carbs before you do the pilot screws. I left mine all year 'cause I was too lazy and only riding on track. The pilot screws were about right but it was always lumpy at tickover. A quick balance sorted that. Then I drained all the fluids and packed it away for the winter. What a Richard.
Dazza2910
Re: Idle speed
Post by Dazza2910 »
Throttle position sensor and carb balance might be a bit beyond me! But will look into that.
Daz
gsh
Re: Idle speed
Post by gsh »
Sorry to bump this but just wondering how on earth I can adjust the idle?
My hands are too big to get more than one finger on the adjuster knob and there's no play at all so no chance of "flicking" it round.
I'm wondering if the screw may be seized - surely it can't be this hard to turn on purpose?
Any tips?
Thanks.
Re: Idle speed
gsh wrote: Sun Oct 17, 2021 10:57 am Sorry to bump this but just wondering how on earth I can adjust the idle?
Any tips?
Thanks.
One finger is enough for me... Snerk, snerk , snerk.... 8O
Give it a spray with some lube...frnr frnr...
If your fingers are really to fat to do it.. Ooooh Mrs ! Then try a flat blade screwdriver...carefully...
Re: Idle speed
Any tips?
Thanks.
I do the same as Mac using my middle finger (longest finger) to adjust the tick-over, and my hands are big too. I take XXL in all my motorcycle gloves to give you an idea :thumbup:
As Mac says some lubrication (WD40 or similar) on the adjuster threads could help,
gsh
Re: Idle speed
Post by gsh »
Thanks. I'll pick up some penetrant spray today and give it a go. I fear that I'm still going to need to MacGyver some sort of tool to initially break it loose though.
Re: Idle speed
gsh wrote: Mon Oct 18, 2021 9:43 am Thanks. I'll pick up some penetrant spray today and give it a go. I fear that I'm still going to need to MacGyver some sort of tool to initially break it loose though.
Do lets us know how you get on :?:
gsh
Re: Idle speed
Post by gsh »
Finally had success with a flat blade screwdriver "flipping" it round. Still a bit of a ball-ache and still no way I can do it with just my (apparently) puny fingers.
Thanks for the tips.
On to the next job!
Re: Idle speed
gsh wrote: Wed Oct 20, 2021 2:47 pm Finally had success with a flat blade screwdriver "flipping" it round. Still a bit of a ball-ache and still no way I can do it with just my (apparently) puny fingers.
On to the next job!
Well done, thanks for letting us know :thumbup:
I only just realised you joined this forum shortly after me 8)
Re: Idle speed
sirch345 wrote: Wed Oct 20, 2021 8:39 pm
On to the next job!
Not as much of a chatter box tho...12 v's 19662 posts... :lol:
Re: Idle speed
MacV2 wrote: Thu Oct 21, 2021 8:38 am
On to the next job!
:lol: :lol: :lol: :thumbup:
It all the keeping you lot inline, that's the problem :lol:
Well some of you anyway :wink: :lol:
