hi all
may be a little dumb
where the tank hinges i've only just notice a black rubber flap!
but where should it go? infront of the shock or under the tank?
cheers
gazbut
black rubber flap??
Re: black rubber flap??
if its the black flap im thinking about it sits under the tank over the top of one of the rear cylinder the seat end..
if you take off the seat there is a single bolt going through the tank and frame.
thats where you use that strange U shaped allen key thing from the firestorm on bike tool kit.
if your having probs with putting it in i will take a photo of it on mine..
hi timbo
i think thats it number 8
just wasn't sure if it lies flat under the tank or hang down in front of shock.
chuxta if you've got time for a pic you'd be a star!
cheers
gazbut
cheers
gazbut
- Phil-VTwin
The 2 slots at the bottom hook over the fixing bracket to create a U shape around the fuel petcock and pipes.
Ride Safe
Phil
Phil
- LutonStorm
As we well know, eh Phil?
Make sure you get it the right way round...!
- Phil-VTwin
Ride Safe
Phil
Phil
will whip the tank off in a mo and try n take some pics to show you where my black flap hangs darling.....
sorry for the delay been a bit busy..
