Rear caliper bolts which part number
Put a new wheel on the storm, tightening up the rear caliper bolts to the required torque and snap the one towards the back of the bike shears, was lucky I could ge the thread out of the support bracket, does anyone know the part numbers for the rear caliper to support bracket bolts, also the brake pad thin metal shim which holds the pads in place.
Re: Rear caliper bolts which part number
For a 1999 model it looks like it's number 16 for the bolt in this micro-fiche if I understand you correctly:-
http://fiche.ronayers.com/Index.cfm/Mod ... KE_CALIPER
PS. I just had another look, and it's the same part number for a 2005 bike, so I would imagine they're all the same.
Part number:- 90180-MN8-006
PPS. Back again
David Silver can order them in for you:-
http://www.davidsilverspares.co.uk/part ... 180MN8006/
You can have a look yourself for the shim you mention.
PPS. Back again
- babysitter
Hi you can find all the part numbers for every model for every bike on this site go to honda and just pick out the year and model .
http://www.mrcycles.com/
Harley Davidson Roadking 1690 / Harley Davidson 1200 Sportster
54 Honda Varadero XL1000 / Honda Firestorm Red,/ BSA B40WD Trials,
/Audi TT 225 / Foard Transit T300/ VW Touareg
While yer fettling that end of the bike check the sleeve (part no. 12) and bolt (no. 13) for corrosion.
As a bonus rear brake parts from the CBR600F4 99-06 are the same.
Cheers peeps some good info there damn prices tho <fook> £6 for a bolt damn I need some KY 1st lol.
can you not buy a non Honda part cheaper? buy a matching pair from probolt or similar?
http://www.tastynuts.com/
I would measure the remaining bolt and get a high grade SS or titainium replacement!................obviously as these mount the brakes, dont scrimp on the grade of steel![Very Happy :D](./images/smilies/icon_biggrin.gif)
I couldn't wait for the parts got from fowlups as they were in stock damn, at least I konw for next time now good link that tastynuts
![Toung Out :p](./images/smilies/sticktongue.gif)
