see pic
It's done 28,000 miles and totally stock, it's just had a major service (3570!!!) by Honda so mechanically it's tip top and overall the condition is so good it's difficult to believe it's nearly 14 yrs old, this is both credit to it's previous owner and tribute to Honda build quaility.
I took it out for a steady 'getting to know you' ride yesterday and did around 160 miles before rain stopped play.
And it preformed pretty well, nice torquey engine (although it is thirsty getting through nearly 2 tank fulls of fuel in 160 miles) the only real problem is the suspension, the front in particular doesn't inspire confidence even under modest braking the the forks are bottoming out and the tyre skipping over ripples, the other thing is it doesn't like to turn in, I've spaced the rear damper top mount 5mm in the hope that it will sharpen up the steering a bit.
Any advice on sorting out the forks much appreciated, I'm not going to change the forks for Blade items so I'm thinking a change of spring and oil will do the job.
