stormingjoe wrote:have had 2 off them led lights in the cyclops at the front, the ally bit fell off both too many vibes methinks!!
i've have 1 in there too but not had any problems yet..
bigspanishmarty wrote:
tattoo wrote:stop being tight marty..the normal capless bulbs are £1 each from spares shops so £3 for 10 blue ones are cheap...mine cost me £5 for 2 bulbs
this bike modifiying business is getting expensive buddy, i cutting down on my expenditure......
you could always get them from the breakers yard too....i got a pocket full when i went for a wiring loom when i was rebuilding my old xr3i....free bulbs
no worries m8...i've got to agree with tony,the blue lights aren't bright enough for you to see the clocks clearly.i'm trying to find white overlays with red numbers,in theory the red bulbs should show the red numbers and the needle tip up bright and clear...but this is only a theory..if not they'll go back to white bulbs
tattoo wrote:no worries m8...i've got to agree with tony,the blue lights aren't bright enough for you to see the clocks clearly.i'm trying to find white overlays with red numbers,in theory the red bulbs should show the red numbers and the needle tip up bright and clear...but this is only a theory..if not they'll go back to white bulbs
if these blue ones aren't any good , i'll change them. there cheap enough, i've got the white rev counter and temp , but the speedo is black.
i'm not sure of the bulb layout, but maybe its possible to run a couple of blue and keep the speedo on white......
not sure how the layout is now but the speedo,tacho and temp have 1 bulb each...give it a try n see what you think bud,i can only tell you how it looked to me...don't be tempted to pull the rubber bungs out by the wires tho,i used a small jewelers screwdriver to start them off
