fused or not?
gafr
fused or not?
Post by gafr »
hi,anybody know if the clocks are fused seperatly?
the bulbs on my speedo all died tonight on my way home,all idiot lights work, speedo is fine as is the mileometer.
i was wondering if each clock is fused indipendantly coz if not then i have a fault from the speedo bulbs to where it joins in with the rev counter clock bulbs.wierd!
Re: fused or not?
Check the PDF manual available in the workshop section
From the wiring diagram
benny hedges
Re: fused or not?
Post by benny hedges »
most likely its just the bulb has gone.
theyre little g10 push-in 3w jobbys.
you might want to put some coloured ones in instead of clear - they look bling :cool2
seb421
Re: fused or not?
Post by seb421 »
I Used T10 SMD LED'S to replace the original filament type T10 bulb, much nicer too
simple to replace just pull out the rubber caps and replace
Stick what ever colour you want in, very cheap of ebay too
