fuel pump fitment
fuel pump fitment
Has anyone fitted a fuel pump to there storm ? im loosing my fuel tank and making a fibreglass dummy tank for my dragbike so need to know if its as simple as fitting a pump from another large capacity carb model bike ?
- benny hedges
Re: fuel pump fitment
yeh m8 its pretty straight forward.
i fitted a pentax pump off a volvo, as long as its a low pressure pump.... you can also use a pump off a zx6 or similar.
there was an article on the front page here regarding this mod, i think using a pump off a cbr600.... stops fuel starvation on fast take off
ok thanks for that, i was looking at a facet pump for 180hp rover engine that runs at 4 psi so shouldnt need a regulator
rover's a bit overkill!!
i'm gonna put a zx9 one on mine when i fit the FCR's, a zx9/zx6 one will be fine for yours.
When subjected to an electrical voltage of at least 50 volts, a cat's tail always points toward the north.
Walbro 255 lpm fuel pumps are good would drain the tank fast tho. really need 500cc + injectors for that not on carbs
