billet6 calipers?
billet6 calipers?
will these fit my bike, i have a cbr954 front end so i'm not sure, because they are for the older blade
http://www.ebay.co.uk/itm/Honda-Firebla ... 35b8d5b7b7
billet6 calipers?
Yours 954 calipers should be the same as the f41 calipers and they fit on my 92 blade forks
Sorry officer
The voices made me do it
Re: billet6 calipers?
tempting, considering i was going to spend over a £100 on cbr954 calipers..........mmmm
billet6 calipers?
If you have standard storm calipers on the bike already with the blade forks they should fit because the storm calipers are the same as the 92-96 blade brakes .
With the billet calipers do you think they will give better braking or is it just bling that might work well or might not
Sorry officer
i was thinking a bit of both to be honest lloydie, i probably won't go for them tbh, i've got other things to sort out, and my brakes are pretty good as is with the 954 discs and what not....
seb421
Post by seb421 »
Mate get the 954 calipers fitted to its forks, What a difference!
its like throwing down a ship anchor, cant beat the stopping power with the 330's and the 954 calipers
i was thinking about searching for some fancy AP Racing items or Brembo's but the 954's are just spot on to be honest
http://www.ebay.co.uk/itm/02-03-Honda-C ... 27c0637803
i reckon i could get these for £225 now they didn't sell for £270, still not sure if its worth it tho.....mmmm
mik_str
Post by mik_str »
FWIW, the Nissin calipers found on the last of the pre-radial Hondas are considered by the those in the know to be among the finest OEM calipers ever offered on production bikes. You apparently have to spend quite a bit of money to get a true upgrade....
mick, i'll probably go for a pair of 954 calipers and master cylinder, i should be able to get them for around the £100 mark. the billet 6 items are probably a bit to bling for me even..... :lol:
mik_str
Post by mik_str »
FWIW, I would recommend getting the SP-1/F4i version (or the 929 also) as they have larger pistons. Combined with any given MC, they will produce more squeeze (albeit at the cost of more lever travel) than the SP-2/954/600RR versions. Of course, you have those monster 330mm rotors so it may be less of an issue for you.....
i'll keep my eyes open for them mick, with the 330 rotors i reckon the 954 jobbies should do the trick :lol:
