Rear Spring Rates
Jester666
Rear Spring Rates
Post by Jester666 »
I'm looking to change the spring on the rear shock and need some advice pleeeze!! :lol:
I'm approx 14 1/2 stone in my gear so what spring rate should I be looking at? lbs/ins or N/mm is fine.
And what length is the spring?
I know some people have gone for Jacougar (spelling?), I'm looking at Faulkners.
The internal diameter of their springs is 2.25"/58.5mm, is this ok?
Thanks Guys as I understand bugger all about the dark art of suspension, its all wizards and pixies as far as I know!! :lol: :thumbup:
mik_str
Re: Rear Spring Rates
Post by mik_str »
Check out the Racetech Web site (http://racetech.com/VehicleSearch) as they have an on-line spring rate calculator. You enter the bike model, intended use (road or track) and your weight and they give you a recommende rate. Easy as pie......
spider13
Post by spider13 »
just tried that website and according to that my bike should be on the floor as im a right fat git :lol:
steve
oldbikeman
Post by oldbikeman »
I have a spring from Faulkners,Good value but will not fit a standard shock,some say a spring around 800-850lb is OK for them but I have found that the 920lb (stock) after a bit of use works best (12 stone).
spider13
Post by spider13 »
thats ok for you jockey type folk but what about us 18st fat gits
steve :biggrin
oldbikeman
Stock will still be stiff.
Jester666 wrote: The internal diameter of their springs is 2.25"/58.5mm, is this ok?
Jester, I'm not sure off the top of my head, but remember the standard Firestorm shock does not have a parallel spring. One end has a smaller diameter measurement than the other.
The Maxton spring I have fitted get around thing by using a reducing collar.
Snoogle
Post by Snoogle »
spider13 wrote:thats ok for you jockey type folk but what about us 18st fat gits
steve :biggrin
Was thinking the same thing, looking at the calculator I'm nearly too effing big to be riding the bike even with modding the suspension lol FML!
