seb421 wrote:oldbikeman wrote:It is liquid cooled just like a car engine so there should not be any temp differences.Both should be 9s of what ever type plug.
I would argue this, rear is going to run hotter liquid cooled or other simply because it has got hot air flowing over it from the front head / engine and the front has cool / ambient air aiding cooling
Not inside the combustion chamber it's not, Seb!
How's the breeze going to get in there, except via the airbox, where it's all mixed together anyway?
Air flowing over the engine doesn't really aid cooling at all on liquid cooled engines- no fins or anything sticking out into the breeze to radiate heat away.
The radiator does all the work, and the oil cooler, if fitted.
Otherwise cars wouldn't have bonnets over the engine...
Plugs should be the same on liquid cooled engines, but may be different on air cooled ones.
Centre pot on a triple often runs hotter, so needs a different plug to the outside ones, as well as front/rear differences.
But only on air cooled engines.
Someone's had a (wrong) idea.... Fit two 9 grade Iridiums.
It won't have done any damage.
Here's what NGK USA say about heat ranges:
Heat Range Selection
Let's make this really simple: when you need your engine to run a little cooler, run a colder plug. When you need your engine to run a little hotter, run a hotter spark plug. However, NGK strongly cautions people that going
to a hotter spark plug can sometimes mask a serious symptom of another problem that can lead to engine damage. Be very careful with heat ranges. Seek professional guidance if you are unsure.
With modified engines (those engines that have increased their compression) more heat is a by-product of the added power that normally comes with increased compression. In short, select one heat range colder for every 75-100 hp you add, or when you significantly raise compression. Also remember to retard the timing a little and to increase fuel enrichment and octane. These tips are critical when adding forced induction (turbos, superchargers or nitrous kits), and failure to address ALL of these areas
will virtually guarantee engine damage.
So even when I have higher compression and 20 more bhp, I still use standard heat range plugs.
