I loctited the cct's in well so really can't be wombled to take the tank off, airbox etc etc to adjust the front one unless it is necessary
Thanks in advance
Iirc it's around 1100 to 1200rpm, but due to some owners getting the spit back through the carbs now and again they set them slightly higher (1200 to 1400rpm) which helps to minimise this.darkember wrote:That sounds fine to me as well just like mine sounds. Only query I have is the tickover speed I noticed your choke was fully in & it sounds alot faster than mine. Incidently what is the correct rpm at idle???
