Boy done good
Well done fella. Don't think the weather report for tomorrow is that good though mate.
Well today me and Lloyd fitted my manual CCT's
Just forgot to turn the fuel tap back on
Although when I was parked on his drive he noticed a nice split and graining in my tyre
looks like it is about to get expensive. Any suggestions on tyres? I use my bike every day and it get through a few miles so I need something that will last but also something that is nice a grippy for when I get onto the twisties. Something that gets sticky quick as well would help. Not to bothered on price as the 2 tyres are rather important. Currently have a pair of maxxis diamonds fitted. Not near the tread wear limit but now req changing.
Suggestions welcomed.
- benny hedges
dunlop sportsmax. last forever, dont square off, stick like sh1t to a duvet and great in the wet too.
no brainer.
no brainer.
and make lots of smoke when the need to do a burnoutbenny hedges wrote:dunlop sportsmax. last forever, dont square off, stick like sh1t to a duvet and great in the wet too.
no brainer.
Which version of the sportmax tyre? Looking on ebay and there is a road smart, qualifer and some which do not say.
I have a qualifier on rear great tyre but by all acounts only get 3000 mile out of itCkennedy wrote:Which version of the sportmax tyre? Looking on ebay and there is a road smart, qualifer and some which do not say.
on the front i have a road smart on bike when i got it all acounts you will get 6-8 thousand on.
If i had the money i would have gone road smart j&s i found cheapest fitted free.
But even the qulifier grips like mad
With you useing it more would go the road smart use higher milage even on rear 6-8 they reckon
More spraying today.
After a coat of Black and a bit of wet n drying.
Then with another coat of Black.
So if I'm lucky again with the weather, I shall be back out giving it all another rub down as there are still a few imperfections. Not so aggressive this time, and another coat of Black.
good work carl keep it up
don't forget to use fuel resistant lacquer on the tank
Got a couple of cans to give everything a final coat over.
Just trying to decide when to apply the decals. Not sure if I should put them straight onto the Black or give it all a coat of lacquer first then put them on.
i would put them on before the lacquer but after you have keyed the black .cybercarl wrote:Got a couple of cans to give everything a final coat over.Just trying to decide when to apply the decals. Not sure if I should put them straight onto the Black or give it all a coat of lacquer first then put them on.
Carbtune pro arrived so balanced the carbs.
I won't leave it a few years next time, there was nearly 100% difference
Won't need to now I don't have to borrow one.
Reset idle, reset TPS. Seems to tickover a lot smoother now. Not bloody surprising really
Started quite a lot of popping and coughing so did a bit of reading about what this might be. Possibly vacuum pipes leaking- went and checked they were fine. Started it and it was fine
Got to use my car for work tomorrow as I have to go pick up the missus but I'll try and get out tomorrow evening for a test. Can't be arsed now, just want some food and a beer
'02 VTR1000-FY Yellow.
- scott02464
That looks brilliant that mate! It's making me want to do all my panels lol :-)cybercarl wrote:More spraying today.
no disrepect to carl, because he looks like he has done a proper job, but matt or satin black nearly always looks good in pictures, its not until you get up close and personal that the flaws in the paint can really show thru, i look forward to seeing it finished when i get back carlos....
Your not wrong there mate. Because I know where the flaws are I can see them in the pics. But they are not there now. Since those pics I have put on another two coats of Black with a wet n dry rub down between coats. Got another two to do tomorrow but I wont be wet n drying between the last two as I want to build the layers up a bit as these will be the last two coats of colour. Then It will be left to dry for 48h before I put 1 coat of lacquer on, then let that dry, then decals. Then lots of coats of lacquer with wet n drying between coats. The only thing I should have done in hindsight, is put a couple of coats of high build primer on before the regular primer.
- mr.john.coates
Mostly today I
- Painted the missus's sun shed with eco-friendly creosote stuff - I'm building "Ride Points" for later in the week
- Polished up the link between gear pedal and gear box, it was neglected and as I needed to adjust the pedal height I got some brasso on it - Aluminium that now looks like chrome
NT650V in Red
VTR1000R in Blue
Pushbike in Yellow
Wife in Bed
VTR1000R in Blue
Pushbike in Yellow
Wife in Bed
