Rh front hanger removal: how?
Flatline
Post by Flatline »
Will be changing Tasums front rh hanger
It looks as though the swingarm bolt has to be taken out :eek2 :eek2 :eek2
So what's the best method?
Re: Rh front hanger removal: how?
You'll need to support the rear end of the bike - hang it from a garage roof / step ladder method
Don't forget to torque the nut back up to spec.
simo
Post by simo »
The back wheel spindle is the same size so you can push it through pushing s/a spindle out keeping every thing in line.
Theres A Hare in The Turnips.
abba stand on the top rear engine bolt, then remove the swing arm spindle :thumbup:
With the swingarm removed it could be the opportunity to renew bearings and grease up the linkages. :thumbup:
simo wrote:The back wheel spindle is the same size so you can push it through pushing s/a spindle out keeping every thing in line.
Good suggestion, Simo- that's what I do if I haven't got to support the bike from the hoist.
This method works with just a rear paddock stand, no other special tools needed.
Use a chock, though, at the rear of the front wheel, as cup-type paddock stands (as opposed to converted-to-bobbins ones) can "walk" further forward up the SA as you move the bike while working on it.
Flatline
Post by Flatline »
Thanks for that
Will sort it out over the next few days
