Replacing engine in my storm the top mounting bolts are rusted in any advice on how to remove them ??????
Any help greatfully appreciated
Engine Removal
Re: Engine Removal
Tony.Mon is your man, he has taken out more engines than the time it takes blue storm gets to 100mph in seconds.
- scott02464
Re: Engine Removal
Now that is fastbazza696 wrote:Tony.Mon is your man, he has taken out more engines than the time it takes blue storm gets to 100mph in seconds.
Re: Engine Removal
Fek off bazza your just jealous cause u have a common as muck red onebazza696 wrote:Tony.Mon is your man, he has taken out more engines than the time it takes blue storm gets to 100mph in seconds.
Re: Engine Removal
I think you might be heading to a hacksaw solution, but Tony will be along with his list of solutions he has tried.
heat & penetrating oil will be the starting point, but when these things seize up sometimes there is no moving them
Re: Engine Removal
You will also need the special castle tool which you can buy but it can also be fashioned out of a standard socket using an angle grinder. Cannot remember the size but someone here will know & add to this postAMCQ46 wrote:I think you might be heading to a hacksaw solution, but Tony will be along with his list of solutions he has tried.
Re: Engine Removal
I made one of them out of a socket, but in the end I bought a double ended tool which has both on a 1/2" square drive..........much easier
Scottyhitachi used it for his engine removal so we know it works, you can borrow it to if you dont already have one
