carb set up advise please ,
Re: carb set up advise please ,
still playin,,,,,,sure ill just report back when its done
its not the dog in the fight its the fight in the dog
bike put out 95hp , from correct dyno
i done the tps mod , and fitted a dyno kit from other carbs , and ive no bother admitting to a schoolboy error i didnt tighten one of the mains and it fell out!
but the bike was transformed (just dont open the throttle or revs too much
) obviously something was amiss,, tbh i suspected a ripped diafram , but a quick spin on the dyno revealed the idle circuit is spot on ,
fine , just sort the top end , opened up the carbs , and there was one of the mains in the float bowl
nearly pissed myself , rang the dynoman and admitted what id done ,
i knew id have to make up for my error so , (didnt tell the dynoman yet
) but ive done the shims / fitted stick coils / balanced the carbs .
so hopefully i can redeem myself
now on dj needles 180 mains 48 pilots , standard airbox , micron carbon cans
loose main jet
yep that wouldn't of helped the top end or the wallet
ah sure ,lloydiecbr wrote:loose main jet![]()
i forgot to fit the velocity stacks once wile i was making changes at the dyno shop
I've done that too. I've also put the carbs back on, airbox on all the screws done up on the lid and then realised I forgot to connect the throttle cables up. DOH, It's a right pain undoing all those screws again
im not alone ,
, must be old age creeping up on me
well ,,,,,
tps mod , dynojet , 180 mains , 48 pilots , (were 45's) standard screw settings , (were leaned off too) standard airbox/ filter (micron cans)
did valve clearences , balanced carbs ,
stick coil mod ,
genuine 100bhp , but bottom rev range midrange , greatly improved , only 5bhp improvement at top , but very different bike to ride
fuel mixture correct all through rev range , (previously lean everywhere )
its geared down a fair bit too
and thats that , com'on big yellow skyball i wanna drive
stick coil mod ,
yep , all good ,,,,, just set set the suspension too , had all the parts so just cost few quid for dyno runscybercarl wrote:![]()
Well done, sounds like you have it pretty much where you want it.
