Right enough fella. How much difference have they made?
Kev L wrote:Right enough fella. How much difference have they made?
The T has become an F.
Ba boom tish, I thank you!
Nickso
Post by Nickso »
Dunno, not had the fecker out on the road yet due to other works....HID convo that I am still working on. Pretty desperate to get it back on the road though. :)
Good luck with it mate. Stick some pics up when you're done.
seb421
Post by seb421 »
Have you used a projector or just stuck a bulb kit in? If it's not in a projector housing then it's not great for other road users, my god they will see you mind, but they won't be best pleased lol
Nickso
Post by Nickso »
Feck knows, I will assume its just the bulb kit as it doesn't look like a projector like my E30 HID convo is.
I converted it from a twin headlight effort. if anyone has a spring to hold the bulb in I will pay decent money for one delivered.....right now the HID bulb is floating about with no spring.
that can't be good..... 8O
Nickso
Post by Nickso »
The rubber doofer holds it in well enough but I wouldn't want to do big miles with it loose.
benny hedges
Post by benny hedges »
Took mine for a good run round north wales and found a slight leak from the new rad... Hoping its the hoses want nipping up.
And the gear linkage fell off cos some tit had forgot to fit locknuts on the adjuster.
Its now got 272 on the clock lol
FFS :lol: I think you going to have to give it the quick once over yourself and check your nuts, bolt's, jubilee clips and whatnot.
Into the garage I went to trace why it didn't start at tescos .
It was the r/r again it was charging good with the lights off 14.4v but only giving out 12.2v with them on .
So I remove the r1 reg and fitted a later finned one now I'm getting a good 14.5v with the lights on or off .
That was my 3rd r/r in two years .
Two of them were from a r1 and the other was the sh1t standard one .
So going by that the r1 regs are just as bad as the standard un-finned crap .
I'm going to be on the look out for a MOSFET now just in case this one packs up !
good work there Lloydie......that a lot of Regulators to kill, makes you wonder if there is some other problem with the generator?
That was my first thought. Could one of the alternater windings be funny?
pete.l
All the failed r/r have been under charging .
I have a spare genny so I might just swap that over after the 23rd run
Need to get a gasket first tho
