Cheers for that, will give you a shout if that's the router go down!AMCQ46 wrote:They need heavy bar weights or there is a lot of vibration (especially if you stay at one engine speed) so of it has short aftermarket ones then swap them back to the steel Honda ones, or get some heavier ones.....I have some extra heavy ones I was using before I fitted renthals if you want to try them
Numb fingers!
Re: Numb fingers!
Re: Numb fingers!
carb balancing and bit dyno time is on the to do list.sirch345 wrote:I would say worth seeing if heavier handlebar weights or originals could help, and as others have said, a lighter grip does make a difference.AMCQ46 wrote:They need heavy bar weights or there is a lot of vibration (especially if you stay at one engine speed) so of it has short aftermarket ones then swap them back to the steel Honda ones, or get some heavier ones.....I have some extra heavy ones I was using before I fitted renthals if you want to try them
I don't know if this would make much difference to handlebar vibration, but when were the carbs last balanced?
Re: Numb fingers!
Dyno day this Saturday :-) check the rideout sectionWattys1 wrote:carb balancing and bit dyno time is on the to do list.sirch345 wrote:I would say worth seeing if heavier handlebar weights or originals could help, and as others have said, a lighter grip does make a difference.AMCQ46 wrote:They need heavy bar weights or there is a lot of vibration (especially if you stay at one engine speed) so of it has short aftermarket ones then swap them back to the steel Honda ones, or get some heavier ones.....I have some extra heavy ones I was using before I fitted renthals if you want to try them
Re: Numb fingers!
I have this and have found that moving the grip to the furthest point away from handlebar end makes a little diffrence in posture but also seems to help in this "numbing" of hand.
tight gloves is another and try to get a pair of soft gloves that bend with your hand rather than buying cheapest (no offence if you dont).
heavier bar ends will reduce it as well but if your sustaining a constant speed then posture is going to be abiggie, no point in hanging on for grim death whilst using motorways, I hold the bars on the motorway if I get numbed with just my palm on the grip and flexing my fingers over the front brake (not pulling it though). I also find a straight arm rather than sloppy wrists helps. Other than that I dunno.
Re: Numb fingers!
Lloydie has just put me in the picture Lets us know if the dyno day helpsWattys1 wrote:carb balancing and bit dyno time is on the to do list.sirch345 wrote:I would say worth seeing if heavier handlebar weights or originals could help, and as others have said, a lighter grip does make a difference.AMCQ46 wrote:They need heavy bar weights or there is a lot of vibration (especially if you stay at one engine speed) so of it has short aftermarket ones then swap them back to the steel Honda ones, or get some heavier ones.....I have some extra heavy ones I was using before I fitted renthals if you want to try them
Re: Numb fingers!
Bad me not keeping uplloydie wrote: Dyno day this Saturday :-) check the rideout section
Re: Numb fingers!
I started using a crampbuster, a plastic wing that you fit to the throttle and it lets you loosen the grip with your right hand when riding.
I found that worked well with the std clipons & fast action throttle [reduced the grip and vibration] and although my plan was to just use it for tedious motorway work, i found it worked well for sporty riding as well.
Dont use it so much with the renthals
Re: Numb fingers!
I've found that as the days pass & me cast gets a bit looser my fingers aren't so numb, cant get a glove on yet but give it time...
Re: Numb fingers!
I find I get a bit numb when doing lots of slow speed stuff or sat in same position for ages on the motorway, I feel as though it makes me automatically put too much weight on my wrists instead of gripping the bike with my legs
I'm fine when actually pushing the bike a bit harder though, anyone else find this?
I still crave a supermoto...
Re: Numb fingers!
Yes, it's definatly easier at higher speeds as the wind takes the weight off. The worst is sitting in traffic in 50 average speed areas on motorways. I have noticed recently that a lot of those average speed cameras are now facing alternate directions so they can catch the plates on bikes. I used to be able to juts ignore them.anyone else find this?
- BigVeeGrin
Re: Numb fingers!
I get no numbness and I have no bar end weights perhaps I have a silky, feather light touch after all
Re: Numb fingers!
No just a fat butt to help the rearward balance :-)BigVeeGrin wrote:I get no numbness and I have no bar end weights perhaps I have a silky, feather light touch after all
Re: Numb fingers!
Yeah ive noticed that mate, i was never "stupid" through them anyway, just in case they decided to do some looking into it and spotted my plate later on the same bit of roadcybercarl wrote:speed cameras are now facing alternate directions so they can catch the plates on bikes. I used to be able to juts ignore them.
Re: Numb fingers!
That's the problem, if you blast through it at 90 and they don't see your plate they will still be able to track you down by checking other places and eventually they'll find your entire journey basically. Of course it's a lot of effort to do this so I guess they'd only do it in stupid cases, but still an absolute PITAcallam_nffc wrote:Yeah ive noticed that mate, i was never "stupid" through them anyway, just in case they decided to do some looking into it and spotted my plate later on the same bit of roadcybercarl wrote:speed cameras are now facing alternate directions so they can catch the plates on bikes. I used to be able to juts ignore them.
- fireballxl5
Re: Numb fingers!
Just like to throw a curve ball here, have you or has anybody here tried foam/sponge grips ? If you've tried all the other good info already mentioned may be worth a try.
