Dyno Day 22nd June 2013.
geodude
Re: Dyno Day 22nd June 2013.
Post by geodude »
AMCQ46 wrote:Its ok, I have calmed down now :lol:
And it wouldn't help, as it would add 5 to yours as well :(
You are lighter than Lloydie so you probably get the power back there Al :Beer Popcorn:
You should have seen how much food Lloyd tucked away today. :Shock1:
Geo you saying I'm fat ?
Ithe frog might have 5 bhp more the the flying banana but I have no chance of keeping up with it on the road as its ridden but a old nutter !
cybercarl wrote:You should have seen how much food Lloyd tucked away today. :Shock1:
I've been starved for a week !
geodude
Post by geodude »
lloydie wrote:Geo you saying I'm fat ?
If I was, that would be a case of pot calling the kettle....etc
Al's skinny :lol:
True aboot the old nutter on the flying banana :P
Lol. Stop exaggerating the gap up to 5 hp it was only 4.5 :lol:
Lloydie and I had to eat martys share of the barby as he and Carl left before it was over and the students couldn't cope with all the protein and carbs as they can only process pot noodle :lol:
Griff1977
Post by Griff1977 »
I now know where those two remaining Quorn sausages went!!
I had a good few hours with everyone, thanks to Lloydie for arranging & Al for coord the money & helping with the compression test-the result was a relief.
I'm going to do as Dyno Kev says- down to #48 from #50s pilots and up to #182/185 from #180/182 mains.
Good meeting you Virt & Gaz- good luck with tinkering with fueling Gaz!
Laters. Griff.
KriegerCCTs,HEL oil lines,+4 advancer,+1/-1 sprockets,6mm spacer,CBR1k Sidestand,'07 R1 R/R,HyperPro springs F&R,Pipe Werx SL Carbons,Oxford sports hot grips,Mori style belly
Immediate plans:Clean it!
AMCQ46 wrote:Lol. Stop exaggerating the gap up to 5 hp it was only 4.5 :lol:
:lol: the youths did bail early ! Told ya they have no stamina
Virt
Post by Virt »
lloydie wrote: :lol: the youths did bail early ! Told ya they have no stamina
Friend had to go home and he didn't know the route :P He had his bedtime y'see. I was more than happy to stay.
Pot noodle? pfft. You obviously don't know how much cooking I do every week :lol:
Space cakes. :biggrin
cybercarl wrote:Space cakes. :biggrin
I've seen them too :-)
The healthy runners
Red mine - 109.14bhp - 73.04 fpt
Blue ancq46 104.96bhp - 72.46 fpt
Green Griffs - 103.98bhp-71.53fpt
Pink Carl's - 98.91bhp - 68.85fpt
The poorly crew .
Pink mine just to show you where a good one is compared to this lot.
Red Carl's run as above .
Blue Gaz.89.46bhp-63.39fpt very ill.
Green agent p 56.41bhp-56.48fpt
It tried to write its name on the chart l
Right, so I need to steal lloydies top end and griffs 5000 to 6000 rpm boost.
Griffs AFR is more optimised between 5 & 6 and looks to be worth 4 bhp in that vital mid range, but Mine is a bit rich. So should I be thinking of dropping the DJ needle one clip, refitting the std needle, or blocking one of the slide drillings ( I followed the DJ instructions and drilled the extra hole)
Lloydie, did you have the 4 deg advancer fitted last yr on the dyno?
AMCQ46 wrote:Right, so I need to steal lloydies top end and griffs 5000 to 6000 rpm boost.
No not last year it was a new addition for this year and I think it helped
How can I be healthy and poorly. Oh and AL just so you know if my exhaust was not blowing I was expecting at least 106.1 bhp (if it matter at all :roll: ) as in my last run. :lol:
