Hi all I am in the process of building a Storm Streetfighter witha 954 Blade front end conversion
I took a punt on ebay and got a pair of what I thought were blade wheels.
The wheels seem to be from a Honda Blackbird but have no markings as they have been polished out
Dose anyone know if the front wheel will fit a 929/954 Blade front end?
Wheels
Re: Wheels
do the discs fit ?
if they do measure the gap between them to se if its the same as the blade .
Re: Wheels
I will check that matey,
I wasn't sure about spacers spindle & bearing diameters ect
Re: Wheels
They are the easy bit to make :-) worry about the discs first .Duffy1964 wrote:I will check that matey,![]()
Here are some bearing sizes that most Hondas use .
The part number might be handy when ordering some
Re: Wheels
as lloydie says check the disc are going to be the right,the spacers and bearings are the easy bit.
isnt the blackbird wheel similar to the storm one?
Re: Wheels
vtrjames wrote:as lloydie says check the disc are going to be the right,the spacers and bearings are the easy bit.
Cheers for the info Lloydie
Yes James it's a 3 spoke like the storm and blade 929, that is why I took a punt as I thought it may have been a 929 wheel as seller was not sure
Re: Wheels
i hope it works for you,
i used 954 tripples, r1 forks wheel and callipers just had to space the calipers in 2mm due to fork spacing. the 929 and 954 wheel was quite rare when i was looking for one or the price was too high
Re: Wheels
Cheers James, didn't know about the R1 option tbh, would have been easier but got a blade 954 complete front end now.
The wheel I took a punt on is not any good as disc stud holes are smaller centres than the blade, but bigger than the storm
I will sell it on and keep looking, I have a 954 wheel, but looks like its had a repair, so will hold out for a better one and keep other as a spare just in case
Thanks for your help fella's
Re: Wheels
never trust the seller of front wheels......
not sure this one will be cheap, as it has a lot of bids already....
http://www.ebay.co.uk/itm/Honda-Firebla ... 3cd317cb0d
Re: Wheels
Are rear wheels OK then.never trust the seller of front wheels......![]()
