New forks
thumperslaw
New forks
Post by thumperslaw »
Some blade forks
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Re: New forks
Nice start on the conversion
Re: New forks
the hard part is finding a cheap wheel thats undamaged and straight but at a decent price. then you'll need the bigger disc's, this is just the begining.... :lol:
Re: New forks
While I'm very happy with my Roger Ditchfield's breathed on Firestorm forks, USD forks do look the business 8)
Re: New forks
Me too except I used my own air. Along with some very helpful correspondence from Roger. The only problem now is that the rear shock feels worse. It's on the lowest setting and too soft and up one setting is too hard.
thumperslaw
Re: New forks
Planning on keeping my 6 spoke front wheel and I'll make my own axle if need be
Are discs bigger on the forks then?
K100 "flying brick"
Re: New forks
Yep
thumperslaw
Re: New forks
Do you need to change calipers also?
K100 "flying brick"
thumperslaw
Re: New forks
:/ this is going to cost abit more then one thought
Going to keep my six spoke wheel tho
Cnc and lathe it will fit....
K100 "flying brick"
Re: New forks
if your keeping the six spoke, you can use the storm brakes, if you were to use the blade 320mm discs, you can make the storm calipers fit easy enough with just a minor bit of dremelling... :thumbup:
Re: New forks
sirch345 wrote:While I'm very happy with my Roger Ditchfield's breathed on Firestorm forks, USD forks do look the business 8)
having ridden carls bike with his rodgered forks.... :lol:
i can honestly say they feel great, if i was doing it all over again, i'd go for the same as carls, they're spot on. but i will also say, the usd are just as good, but look alot cooler..... :wink:
and the extra mm of front disc helps no end with the braking.... :thumbup:
and yes carls front end does highlight the rearends short cummings. i'm sure another rear shock will be on carls wanted list for the future... :thumbup:
Re: New forks
agentpineapple wrote:the hard part is finding a cheap wheel thats undamaged and straight but at a decent price. then you'll need the bigger disc's, this is just the begining.... :lol:
Try finding a straight SP2 front wheel..... :eek2 That one took a while.....
Re: New forks
yup, sp parts are a lot harder to find than blade parts, and it'll only get harder, i've bought 7 or 8 different front wheels over the last 3 or so yrs, probably 50% have had problems, tbh you should only buy a front wheel in person so you can check it over, but we all know thats not always possible... :(
Re: New forks
cybercarl wrote:Me too except I used my own air. Along with some very helpful correspondence from Roger. The only problem now is that the rear shock feels worse. It's on the lowest setting and too soft and up one setting is too hard.
That's the only down side if there is one. I managed to get hold of a Maxton rear shock spring suited to my body weight for the standard Firestorm shock, I'd say definitely an improvement.
