Alternative throttle cable
spikenipple
Post by spikenipple »
Does anyone know if there are any longer throttle cables (specifically the 'pull' cable) available that will fit the 'storm?
With the SP1 front end I have on my bike, the cable has always been pulled very slightly when at full left lock, causing the bike to rev up. It's routed with the cable coming up from the housing, round the front of the r/h fork and under the yoke to the frame.
I have tried a few alternative positions but none of them are any better.
Re: Alternative throttle cable
spikenipple wrote:Does anyone know if there are any longer throttle cables (specifically the 'pull' cable) available that will fit the 'storm?
Try here they will make whatever you want...
http://www.venhill.co.uk/
seb421
Post by seb421 »
what i did was twist the throttle housing round that gave it enough slack with the 954 front
alexmac
Post by alexmac »
hi, have a look at my photo's. page 12 on,workshop. vtr swingarm & usd fork conversion.
am useing standard twistgrip houseing and cable's. with 929 blade bar's (gained about 50mm).
don't khow if you've already tryed this.? atb alexmac.
suburban guerrlla
Post by suburban guerrlla »
I have a venhill quick action throttle on mine. They supply all you need in the kit to make the cables - but it is not a simple task. Usually you solder the ends on but with stainless steel cables getting solder to stick can be really difficult. You pass the cable through the end hole, splay it a bit and are supposed to get it to stay apart with solder. I have given up doing this. Use superglue instead. It will do the job for a throttle cable.
spikenipple
Brittle superglue on a flexible throttle cable? 8O No thanks!
i think the early blade one is a little longer but cant be sure
suburban guerrlla wrote:I have a venhill quick action throttle on mine. They supply all you need in the kit to make the cables - but it is not a simple task. Usually you solder the ends on but with stainless steel cables getting solder to stick can be really difficult. You pass the cable through the end hole, splay it a bit and are supposed to get it to stay apart with solder. I have given up doing this. Use superglue instead. It will do the job for a throttle cable.
you couldn't of used enough heat on the join .
i used to braze the ends on or make my own but cant be bothered these day when you can buy them ready and a a good price too
mik_str
Post by mik_str »
I recall reading somewhere the F4i cables were longer but can't promise it to be true.......
Take your cables to a breaker- they'll have boxes of them.....
