Engine cover bolt sizes and others
Re: Engine cover bolt sizes and others
Bottom yoke pinch bolt size, 45mm (including head) m10-10mm.
Added thanksoorwullie43 wrote:Bottom yoke pinch bolt size, 45mm (including head) m10-10mm.
The bottom yoke pinch bolts take the price to £11 delivered. I mentioned to him he may get a few other enquirers from this site.
here you go, not cheap tholloydie wrote: Go on then measure them as mine are fireblade and different tho fairing bolts might be hard to find tho I wouldn't mind a set in titanium
http://www.pro-bolt.com/titanium-fairin ... 97-00.html
Yep the price will go up as the list gets bigger so pick and choose the ones you want :-)parkergb6 wrote:The bottom yoke pinch bolts take the price to £11 delivered. I mentioned to him he may get a few other enquirers from this site.
Lloydie,
Been contact with guy regards buying bolt etc and he asked what they were for as he had the same inquiry obviously yourself and others. I've let him know what bike it was just wondered if you'd mind if I let him have a copy of the initial list or if you wanted to send it to him i.e. where they go etc.
Thanks for excellent list has given me the incentive to do my bolts.
The ebay listing number he has put them under guys is 321235092423.
Good work Guy's I have just ordered a set
Please remember you lot that when the list in the first post is added to any links to listings will be wrong .
lloydie wrote:Please remember you lot that when the list in the first post is added to any links to listings will be wrong .
This was listing for engine casing bolts as per your first list Lloydie
More added
£158.06 for 8 boltsplayerone wrote:here you go, not cheap tholloydie wrote: Go on then measure them as mine are fireblade and different tho fairing bolts might be hard to find tho I wouldn't mind a set in titanium
4 screen and 4 side how the fook can that cost £158
Just a thought, my clips for the brake lines are a bit sad looking! Any body any idea where we could get some shiney ones?
Try a Honda dealer.oorwullie43 wrote:Just a thought, my clips for the brake lines are a bit sad looking! Any body any idea where we could get some shiney ones?
Have bought a set too - though I did mine with leftovers from an SZR660 and don't think some were as long......
How about stainless self-tapping or fairing (not screen) screws?
