seb421
Post by seb421 »
Everything is clean now, everything!!
Hoses have been done with Vinyl and rubber care, engine cleaned all over with a toothbrush and cotton buds, all the corrosion on the rads is polished away, inside and outside of the fairings are spotless too
Oil and Filter just changed too
Ckennedy
Post by Ckennedy »
That thing does look nice when all clean seb. Give yourself a pat on the back :thumbup: job well done. Fancy doing mine?
Now go and get it dirty :-)
kenmoore
Post by kenmoore »
Tooth brush and kerosene, then wipe over with WD40 and a rag.
You just have to stay on top of it.
All part of the ritual after a ride.
South Coast
New South Wales
Australia
kenmoore
Post by kenmoore »
Fitted mesh to the running light and front fairing vents, can't decide whether to do the radiators .
Also am making up mesh in fills for the gap between the swinger and hugger that I have fitted.
Any thoughts?
Will the radiators be too much?
South Coast
New South Wales
Australia
Not the little light :-( but the rest looks good :-)
Today I got it started and then swapped virts discs and lines then bleed his breaks
Not the bike, started mucking out the man cave so I can get on winter modding, think a bomb had gone off in there 8O! Will post before and after pics WHEN :roll: I'm done :thumbup:
Watty wrote:Not the bike, started mucking out the man cave so I can get on winter modding, think a bomb had gone off in there 8O! Will post before and after pics WHEN :roll: I'm done :thumbup:
It's got to get worse before it gets better ! It's worth it in the end :-)
Virt
Post by Virt »
lloydie wrote:Today I got it started and then swapped virts discs and lines then bleed his breaks
Make it sound like I didn't do anything then :wink:
I mean, I didn't. But you could at least make me sound kick ass instead of a whiny little sh1t that can't do anything :lol:
bigtwinthing
Post by bigtwinthing »
kenmoore wrote:Fitted red anodised sprocket nuts.
Image :beer:
are they "baffles" in those exhausts??? what a waste!!! bike looks good though. :D
Sorry youth .
Virt had another lesion on how to undo a bolt and used his hand mussels to pump the break lever while I operated the bleed nipple ! . I also had Virt apply lube to some bolts and find tools oh oh and he topped up the break res with the finest dot 4 I had as his had been shaken up and could be used (full of air bubbles ) .
Tho I must say only a few more lesions and he might be able to get dressed without supervision :-@
Virt
Post by Virt »
lloydie wrote:Sorry youth .
<3 good boy :lol:
You were :clap:
keep up the good work ymv............ :thumbup:
so are virts brakes all sorted now?
